Hello All,
I've put together a brief demonstration vide here showing the serial ICD capabilities in Flowcode 11.
https://youtu.be/NAqDwGC7qGM
Please feel free to add comments or questions below.
Flowcode 11 Serial In Circuit Debug (ICD)
- Has thanked: 625 times
- Been thanked: 833 times
Re: Flowcode 11 Serial In Circuit Debug (ICD)
This ICD feature looks really interesting.
At the ned of your video, you mention that it may require a custom file to work with certain microcontrollers.
My projects are mostly using PICs and controlleres that all have UART which I typically dump diagnostics out to through an FTDI Serial to USB and into a Terminal (or more often now, FC App dev)
18F2585
16F15324
dsPIC33EV....
Pi PICO
Are these suitable candidates for the ICD method you covered in the video?
Thanks, J.
18F2585
16F15324
dsPIC33EV....
Pi PICO
Thanks, J.
Yes those are all great targets and should all work fine with the new ICD.
The two 8-bit PIC devices should work fine with a simple tweak to the device definition file. You can amend the original FCD file in the "C:\ProgramData\MatrixTSL\FlowcodeV11\FCD\PIC" folder or you can make a copy of the file and that way you are immune to library updates overwriting your changes. If you want to overwrite the original then make a backup of your changes so you can restore them if you happen to do a full library update.
The change you need to make is right at the bottom of the chip definition FCD file. Open the file with a text editor and scroll right down to the bottom of the file to find the test section. It will probably look like this.
Simply change to add the ICD3 definition. Channel is the hardware Channel to use, RXPort and TXPort are the port letter, 0=A, 1=B etc, RXPin and TXPin are the bit of the pin being used.
If your chip has a remappable UART then you can set the default pins by adding to the end of the inline main start code section of the FCD. Add the UART to your project and setup the pins to see the registers and values.
Last to add the option to let you select the COM port in the project options or to auto detect the port you can add the comminfo section as the first child node inside the device section.
If your making your own version of a FCD then you also need to scroll to the top of the file and do a couple of things.
1) Delete the header lines from the top of the file - they look like this.
2) In the device section add in a new file="" option with the filename of the new FCD file.
would become
If you have specific channels, port and pins you want to use on specific devices then let me know and I can make all the FCD changes for you.
16-bit PIC and Pico families don't have ICD support yet but I can happily look into this if it's useful for you.
<test >
<icd >
<clock port='0' pin='1' />
<data port='0' pin='0' />
</icd>
</test>Code: Select all
<test >
<icd >
</icd>
<icd3 type='com' channel='5' baud='115200' rxport='6' rxpin='3' txport='6' txpin='2' autodetect='0' />
\n\tRX5PPS = 0x33;\n\tRG2PPS = 0x14;\nCode: Select all
<device file="E-blocks3 8-bit PIC Programmer" name='E-blocks3 8-bit PIC' namealt='18F67K40' product='PIC' cal='PIC' family='18F' bits='8' scannable='EB3' >
<comminfo>
<com pid="0031" vid="12BF" devdesc="E-blocks3 PIC" />
<com pid="0403" vid="6015" devdesc="E-blocks3 PIC" />
</comminfo>1) Delete the header lines from the top of the file - they look like this.
<!-- CRC: 90CF26913586BBA787FE92D5537719330A836487DCEEAA0B715200033895AA96FC1CCCFA5F4233CFD1787D44233A22EA9A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF5FE80C4F0E92FCB49B91C6DBCE39A5FCDEF4D23B1B19957934047C2A628B885B8ADFFB39369AE4C02500452164639148AE79202B87CB6969266B11C77E5F1405E961B9896EC0DFA49A041DF81AFAACC767F96566B6F27940E086944AE325796A68F555CCBBDFD86D98F6218D9A7B28036E96C0ED9BC8FA8DE08DB0CC5B99E58558FAE3087E8A87EE9 -->
<!-- REVISION: 1.0 -->
<!-- GUID: 3E48EC1C-B96E-47FC-AA98-AF9A0CAC6C54 -->
<!-- DATE: 08\08\2022 -->
<!-- DIR: FCD\PIC\16F1503.fcdx -->Code: Select all
<device name='16F1503' product='PIC' cal='PIC' family='16F' bits='8' >Code: Select all
<device file='16F1503_custom' name='16F1503' product='PIC' cal='PIC' family='16F' bits='8' >16-bit PIC and Pico families don't have ICD support yet but I can happily look into this if it's useful for you.
Finally got time to look at this again.
PIC18F2585 on a stand alone custom PCB.
Can this method only be used with direct USB programmed devices? since you need to Program & do ICD over a common serial link.
I use PICKIT3 or PICKIT5 for programming, but also have various old Eblocks systems, flowkit1 & 2 etc.
I followed the instructions as given above and created an custom FCD for a PIC18F2585. Attached. and change to this in my FC project and enable ICD, this seems to send OK to the PIC.
For the Port and Pin settings, should I be using the UART hardware pins. Tx C6 Rx C7
or the programming pins?
Thanks, J.
Thanks, J.
- Has thanked: 748 times
- Been thanked: 808 times
I have a SparkFun RedBoard and thought I'd try out ICD on it.
After modifying the fcdx, it works brilliantly — highly recommend giving ICD a go if you haven't tried it before. It's great being able to single-step and watch ADC variables update live as you turn a hardware pot.
If you have a SparkFun RedBoard, browse to this location in File Explorer (it's hidden by default, so just paste the path into the address bar):
Replace the original file with the attached version.
A few notes:
If Flowcode is already open, you'll need to reload your project for the change to take effect.
Running any component updates will overwrite this file, so you'll need to reapply it afterwards.
The INT0/INT1 interrupts were assigned to the wrong pins in the original file — fixed in this version.
I've also changed the pin layout so it reflects the physical board layout rather than the raw ATmega328P pinout.
%ProgramData%\MatrixTSL\FlowcodeV11\FCD\ARDA few notes:
- SparkFun RedBoard.fcdx
- (16.05 KiB) Downloaded 26 times
Hi Jay,
I've made a quick change which is to add the interrupt handler. Hopefully this should work correctly now.
Yes that's correct.For the Port and Pin settings, should I be using the UART hardware pins. Tx C6 Rx C7
