So Obvious.......
Has thanked: 451 times
Been thanked: 675 times
Re: So Obvious.......
Post by chipfryer27 »
Hi Steve
Will do.
At present though, providing a way for the FC MQTT component to option "Clean Start" and QoS would be great, as would, what I believe is much needed, an alternative to espressif. To that extent I have been looking at the RNWF02 board from Microchip which would / should allow any PIC or uC internet connectivity. Of course Pico 2W would be very welcomed :)
It was a few months back that I last used WD and after "re-figuring it out" as it had been a while since I previously played, I found it to be quite easy to use for whatever it was I was doing then (I think I was grabbing time from my server). I will probably use it to also grab and display pertinent info from my database too.
Has thanked: 622 times
Been thanked: 827 times
I've had a go at the MQTT upgrades and have something here but want it to be tested a bit more before we release it to the update system.
I've implemented the QoS and Clean Start as well as a number of other things.
Have a play and let us know how you get on. I'll try and find some time for some testing too :D
MQTT_Client.fcpx
(16.56 KiB) Downloaded 7 times
Many thanks for taking the time to update.
Ordinarily I'd be testing it as I type, but last night I "accidentally" opened a few quality bottles of rum, bourbon and Islay's finest with my neighbour, and for the life of me can't remember too much other than watching a fox and deer stroll past together. I'm as certain as I possibly can be that this did happen and wasn't some AI generated hallucination (AI = Alcohol Induced <s>). I will look through my CCTV as a sanity check once I find out where I left the remote control... :)
My plans for today are now written off...... so I should get time this afternoon to test.
Ardbeg Corryvreckan..... Making the best of bad decisions..... :lol:
I'm still not firing on all cylinders but did manage a quick QoS test and it seems to be working fine. I had my chart send messages to my broker, then disconnected my PC client, sent another message and reconnected PC client. It then obtained the message.
Thanks again for the updated component.
