Electrical Test Projects
Has thanked: 620 times
Been thanked: 823 times
Hello Everyone,
We are going to be working on some applications for electrical test to help demonstrate the power of app developer in Flowcode 9 and also to create some examples that are easy to follow and hopefully inspire some more knock on projects.
The first project we had in mind is an Arduino Uno based component tester that can get the value of resistors and capacitors as well as maybe testing out diodes and transistors. This would all be controlled via an App developer app alongside the Arduino USB slave firmware. In th next few days I'll create a simple circuit to go on the Arduino as well as a App Developer program and a video to showcase the project.
Is there anything specific that anyone would like to see being implemented as part of this project or even turning into a seperate project for next time?
kersing
Has thanked: 81 times
Been thanked: 65 times
Re: Electrical Test Projects
Post by kersing »
Could you include measuring coils as well?
Hi Jac,
Yes good shout I'll have a go with coils too to get their resistance and inductance.
jgu1
Has thanked: 846 times
Been thanked: 205 times
Post by jgu1 »
Hi Ben!
Exiting :D What about Triac, Thyristor and Mosfet, germanium/silicium and zener diode schottky if possible. :D
Br Jorgen
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Post by p.erasmus »
Hi Team,
Nice idea however my question is why must it always be based on an Arduino just asking :D
I also like jgu1 idea, transistors MOSFET test will be interesting
We wanted to use some hardware that is very easy to get hold of and also most people might already have one sat in a drawer. The project should work equally well on just about any MCU with analogue and digital pins and a connection back to the PC. One of our other SCADA slave targets for example would work just as well e.g. ECIO, ESP32 or dsPIC E-blocks2 board to name a few.
Out of interest what MCU would you like to see and maybe we can base our next project around this?
Has thanked: 298 times
Been thanked: 464 times
p.erasmus wrote:
Fri Jan 08, 2021 8:40 am
That question highlights what I believe is one of the more powerful aspects of Flowcode: projects can easily be transferred to other targets, often with few or no coding changes. We probably don't push this enough.
So while this project will be written around an Arduino, it should be simple to port to another platform or chip.
p.erasmus
Post by p.erasmus »
Hi Team.
Thanks guys make sense and I understand your view :D
I think we very little push the dsPICs, which has a lot of potential although a 16bit mcu these out perform many 32bit mcus,
Hi Peter,
I agree the 16-bit PICs are little powerhouses :D They are certainly one of my go to devices.
I've made a start on the component test project here if anyone would like to have a go or try and help push the project forwards.
viewtopic.php?f=3&t=117&p=579
alanwms
Has thanked: 26 times
Been thanked: 8 times
Post by alanwms »
Mosfet and IGTB devices under test might require the ability to measure the turn on and off time
