ESP32 - python.exe doesn't support asyncio --no-hints
Has thanked: 626 times
Been thanked: 833 times
For anyone experiencing this.
python.exe doesn't support asyncio. The issue can be worked around by re-running idf.py with the "--no-hints" argument.
This seems to be cropping up a lot at the moment. Until we work out a catch all fix anyone with this problem will need to do the following.
First make sure you are fully up to date with libray updates by clicking Help -> Library Updates, changing Files in use to Full Database and getting the latest files. Next check if you can compile, it could be we have already solved this issue with an update.
If you're still getting the error then continue.
Navigate to this directory by copying and pasting the path into your file explorer address bar.
V9
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch
V10
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch
Open the file esp32_build.bat in a text editor by right clicking the file and selecting edit.
Find these lines.
@idf.py build
REM @idf.py --no-hints build
Move the REM up a line so you get this instead, the REM is basically commenting out the rest of the code on the line.
REM @idf.py build
Save and close the file.
Now repeat with the file esp32_prog.bat
These lines
@idf.py -p %PORT% -b %BAUD% flash
REM @idf.py --no-hints -p %PORT% -b %BAUD% flash
Change to look like this.
REM @idf.py -p %PORT% -b %BAUD% flash
Hopefully Flowcode can now compile correctly.
Be careful when doing library updates as this will try and overwrite the batch files back to factory defaults. If you do overwrite the files you may have to re-apply the fix.
Not sure what has changed but i'll keep investigating how we fix this for everyone without breaking existing working setups.
Some advice on creating a working ESP32 toolchain is offered here.
viewtopic.php?p=11300#p11300
nmjb18
Has thanked: 10 times
Re: ESP32 - python.exe doesn't support asyncio --no-hints
Post by nmjb18 »
This fixed my issue, thank you. I will watch out for the permanent fix.
Thanks!
RGV250
Has thanked: 46 times
Been thanked: 48 times
Post by RGV250 »
That fixed it for me as well. It is just as well it is quite a capable and cheap device to make it worth the initial pain setting it up.
Bob
pmgreene01
Has thanked: 4 times
Been thanked: 5 times
Post by pmgreene01 »
I just had this issue and doing the library updates resolved it for me. Thanks.
george_b
Has thanked: 13 times
Been thanked: 3 times
Post by george_b »
Hi all,
Having the same issues after installing the ESP Tool chain! I expect this kind of fixes to be done on the feature updates of FC10 without the need of release FC11 !
Thanks for the information of this topic i fixed the compilation error and now the ESP package is working.
George
Has thanked: 749 times
Been thanked: 809 times
Hi George.
The only fix required is a Full database library update, as the editing of the file is no longer required for FC10.
No need to wait for Flowcode v11 for a fix.,
