PIC18F86/87 J72
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Flowcode v10 PIC18F86/87 J72
Post by SpeedPIC32 »
Hello team
how fast can the PIC18F86/87J72 be recorded?
Have a look at the data. I am currently building a small measuring device and would like to use it there.
Dual-channel 16-/24-bit Analog Front End (AFE) with Delta-Sigma A/D Converters and high-gain PGAs for 90 dB SINAD and -101 dBc THD (to 35th harmonic) performance
12-bit, 12-channel, 100ksps SAR A/D Converter
LCD driver for up to 132 pixels with voltage boost regulator
Hardware Real-Time Clock & Calendar
Charge Time Measurement Unit (CTMU)for temperature sensing and capacitive touch
Two Analog Comparators
Two UARTs
One Master Synchronous Serial Port (MSSP) support SPI™ and I2C™
Four Timers
Two Capture/Compare/PWM (CCP)
Up to 12 MIPS performance
Internal oscillator support 31kHz to 8MHz and 4xPLL
8x8 Single Cycle Hardware Multiply
nanoWatt low power with Run, Idle and Sleep modes
Brown-Out-Reset (BOR)
Low Voltage Detect (LVD)
Operating Voltage Range: 2.0 to 3.6V for Digital and 12-bit ADC; 4.5 to 5.5V for 16-/24-bit Analog Front End (AFE)
with kind regards
SpeedPIC32
Re: PIC18F86/87 J72
Hello team
isn't this PIC interesting enough?
Which other PIC has such a 16 / 24 bit AD converter on board?
Is this not even worth an answer?
Or are you all on holiday.
I would be very happy if this PIC finds its way into Flowcode
with kind regards
SpeedPIC32
Has thanked: 647 times
Been thanked: 856 times
Re: PIC18F86/87 J72
Interesting you've not had a reply, sorry about that.
We are investigating a newer version of the XC8 compiler both for PIC and AVR devices and so hopefully we will have some news on this soon. There is more to it then updating the compiler, we will also have to create the device definition files and update our CAL code but it's certainly on our short term to do list.
SpeedPIC32
Flowcode v10 Re: PIC18F86/87 J72
Hello everyone
It's been over a year since I've been waiting for this chip / or its conversion / re-recording.
Now it should be possible to record the chip.
Greetings SpeedPIC32 :roll:
Has thanked: 795 times
Been thanked: 858 times
Re: PIC18F86/87 J72
The next Target device created will be the PIC18F8xJ72
I don't have the hardware.
Would you mind testing on your hardware?
Re: PIC18F86/87 J72
Hello. I have now created both PIC18F86J72 & PIC18F87J72
You will need to close Flowcode.
If you then browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
%ProgramData%\MatrixTSL\FlowcodeV10\FCD\PIC\
You can then place both fcdx files.
When you open Flowcode the new targets should appear within Flocodes target devices.
18F87J72.fcdx
(23.72 KiB) Downloaded 248 times
18F86J72.fcdx
(23.72 KiB) Downloaded 236 times
SpeedPIC32
Re: PIC18F86/87 J72
Hello, that's great.
I'll test it out.
Thank you very much.
Re: PIC18F86/87 J72
You're welcome.
Fingers crossed all is working for you.
