Ribbon Toolbar
<sidebar>Sidebar: Getting Started</sidebar> The Flowcode environment consists of a main work area in which the flowchart windows are displayed, several toolbars that allow icon and components to be added to the flowchart application, windows that allow the status of the microcontroller and attached components to be viewed and windows that display variables and macro calls when the flow chart is being simulated.
1) Icons Toolbar
2) Components Toolbar
This toolbar displays the external components that can be connected to a microcontroller. Click on a component and it will be added to the microcontroller in the Microcontroller view. The pin connections and properties of the component can then be edited.
Docking and Undocking the toolbars
File:Undocked Icons Toolbar.png
File:Eg Tools and views Grab Bar Area.png
3) Chip View
4) Flowchart Window
5) System Panel
8) Icon Lists
9) Simulation Debugger
10) Toolbar
Use this command to display and hide the Toolbar, which includes buttons for some of the most common commands in Flowcode, such as File Open. There are also buttons for starting, stopping and pausing the simulation on the toolbar.
11) Status Bar
12) Current Zoom level
The currently selected Zoom level is displayed on the right side of the Status Bar.
