API Panel.Position
Revision as of 11:09, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Coordinate manipulation functions
This class is contained within Panel.
Sub-classes provided for this class
Math Coordinate maths functions
Camera Camera positioning
Functions provided for this class
Get Gets a handle to an object representing the components current position
GetOrigin Gets a handle to an empty position
Set Sets an objects position based on a component or pre-defined position
SetCoords Sets an objects coordinates based on a position
SetScale Sets an objects scale based on a position
SetRotation Sets an objects orientation based on a position
GetBox Gets a handle to an object representing the components bounding box position
Morph Blends positions from two sources to a destination
Animate Blends positions from two sources to a destination over time
StopAnimate Stops all animations started by this component
MoveAlong Moves the object by the given offset relative to its parent along an axis
MoveBy Moves the object by the given offset relative to its parent
MoveTo Moves the object to the given coordinates relative to its parent
ScaleTo Sets the objects scale to a value
ScaleUp Multiplies the objects scale by a value
ScaleDown Divides the objects scale by a value
RotateTo Rotates the object to the given rotation
RotateAlong Rotates the object by the given rotation along an axis
RotateX Rotates the object around the X axis
RotateY Rotates the object around the Y axis
RotateZ Rotates the object around the Z axis
GetCoords Returns the positions coordinates in (X,Y,Z) array
GetScale Returns the positions scale in (X,Y,Z) array
GetQuat Returns the positions quaternion in (X,Y,Z,W) array
GetEuler Returns the positions euler angles in (P,Y,R) array
See also
