Examples and Tutorials
Jump to navigationJump to searchThis page contains organised exercise used throughout Flowcode Help section, and further exercises which are not featured in the Flowcode Help structure.
| Flowcode Help | |
| Creating a Flowchart | Preparing and and planning a program by adding icons to a flowchart to be expanded into a program. |
| Configuring Icons and Variables | Configuring the flowchart icons and variables to effective operate a program using components. |
| Adding Devices to a Program | Adding, configuring and manipulating components for suitable and effective use in a program. |
| Simulating a Program | Testing and simulating a program in Flowcode using various methods and techniques of simulation. |
| Transferring a Program to the Microcontroller | Testing and running a program on hardware, compiling to a chip and the process required to do so. |
| Documenting a Flowchart | Using comments to explain and describe your Flowchart and the process of the program. |
| Expanding a Program | Expanding your program further to increase functionality, effectiveness and efficiency. |
| Using Component Macros | Creating and expanding a program by using icons and components, specifically Component Macros. |
| Using Macros | Using Macros and local variables to effectively create and organise a program including components. |
| Inserting Code Into Flowcode | Adding custom code into a program and integrating it into the flowchart for use with components. |
| Using Interrupts | Using interrupts, custom interrupts and timers to call macros and configuring interrupt properties. |
| Debugging Hardware and Software | Debugging a program in simulation and on hardware using various methods such as ICD mode. |
| Using Analogue Input Devices | Creating a functioning program consisting of an LED and an analogue (ADC) dial to drive the system. |
| Dashboard Panel & System Panel | |
| Adding Objects to the System Panel | Using the System Panel with components and configuring options for suitable use with components. |
| Controlling Shapes on the System Panel | Manipulating and displaying components on the System Panel and controlling the camera and views. |
| Adding Objects to the Dashboard Panel | Configuring the Dashboard Panel to manipulate components and component properties accordingly. |
| Controlling Multiple Objects | Using the Dashboard and System Panel together to effectively program and simulate a system. |
| Controlling Collisions on the System Panel | Configuring the System Panel to display and control object collision using different methods. |
| Component | |
| Create an LED Component | Creating a flowchart revolving around an LED component driven by simulation macros and functions. |
| Exporting the LED Component | Exporting and saving the component, including simulation macros and properties and variables. |
| Importing the LED Component | Importing the component into a new flowchart and preparing it for testing in simulation. |
| Testing an Imported Component | Testing the imported LED by creating a flowchart program to run in simulation to test the component. |
| Building a Complex Component - the Traffic Cone | Building and programming a component by grouping multiple elements on the System Panel. |
| Exporting the Traffic Cone | Exporting and saving the component, including simulation macros and properties to prepare for testing. |
| Importing and Testing the Traffic Cone | Import the component and test it in simulation by calling the previously programmed simulation macro. |
For further tasks to practice and complete see Labs at the end of the Flowcode Help section
