Recent Changes - Search:
<^< Assessment: Active Circuits | Course index | Written Questions: Active Circuits >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits ##
Multiple Choice Quiz: Active Circuits ## Written Questions: Active Circuits ## Assignment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Assessment: Active Circuits | Course Index | Written Questions: Active Circuits >^>(:nl:)
>>frame round<< Question 1:
When triggered by a negative pulse, the circuit shown produces:
(a) a single rectangular pulse with duration determined by R1 and C1
(b) a single rectangular pulse with duration determined by R2 and C2
(c) a series of rectangular pulses with duration determined by R2 and C2 >><<
>>id=example1 class=question margin=10px frame round<< Answer: B >><<
>>frame round<< Question 2:
Which one of the waveforms shows a typical waveform for the base-emitter voltage of an NPN transistor used in a simple common-emitter amplifier circuit operating from a 10V supply?
(a) Waveform (a) (b) Waveform (b) (c) Waveform (c) >><<
>>id=example2 class=question margin=10px frame round<< Answer: C >><<
>>frame round<< Question 3:
In the circuit shown, which component provides DC isolation at the output?
(a) C1 (b) C2 (c) R2 >><<
>>id=example3 class=question margin=10px frame round<< Answer: B >><<
>>frame round<< Question 4:
The figure shows a simple DC power supply. Which one of the following gives the approximate output voltage with no load connected?
(a) 6V
(b) 12V
(c) 17V >><<
>>id=example4 class=question margin=10px frame round<< Answer: C >><<
>>frame round<< Question 5:
In the circuit shown, which components act as a filter to improve smoothing?
(a) T1 and D1
(b) C1 and R1
(c) R1 and C2 >><<
>>id=example5 class=question margin=10px frame round<< Answer: C >><<
>>frame round<< Question 6:
In the circuit shown, IC1 is a 555 timer connected in:
(a) astable mode
(b) bistable mode
(c) monostable mode >><<
>>id=example6 class=question margin=10px frame round<< Answer: C >><<
>>frame round<< Question 7:
The amplitude of the pulse generated by the circuit shown will be:
(a) about 12V
(b) exactly 6V
(c) the same as the trigger input >><<
>>id=example7 class=question margin=10px frame round<< Answer: A >><<
>>frame round<< Question 8:
In the circuit shown, which one of the following gives the voltage gain?
(a) R2 - R1
(b) - R2/R1
(c) 1 + (R2/R1) >><<
>>id=example8 class=question margin=10px frame round<< Answer: B >><<
>>frame round<< Question 9:
In the circuit shown, the feature 'X' is:
(a) the inverting input
(b) the non-inverting input
(c) the positive supply input >><<
>>id=example9 class=question margin=10px frame round<< Answer: B >><<
>>frame round<< Question 10:
Which one of the following gives the voltage gain of the circuit shown?
(a) 2 (inverting)
(b) 3 (inverting)
(c) 30 (inverting) >><<
>>id=example10 class=question margin=10px frame round<< Answer: A >><<
>>frame round<< Question 11:
(a) R1 - R2
(b) R2/R1
>>id=example11 class=question margin=10px frame round<< Answer: C >><<
>>frame round<< Question 12:
In the power supply circuit shown:
(a) D1 to D4 form a half-wave rectifier
(b) D1 to D4 form a bridge rectifier
(c) D1 to D4 form a diode stabilizer >><<
>>id=example12 class=question margin=10px frame round<< Answer: B >><<
>>frame round<< Question 13:
(c) the negative supply input >><<
>>id=example13 class=question margin=10px frame round<< Answer: A >><<
>>frame round<< Question 14:
In the circuit shown, if V'_IN_' = 1.5V, which one of the following gives V'_OUT_'?
(a) -3V
(b) 3V
(c) 4.5V >><<
>>id=example14 class=question margin=10px frame round<< Answer: A >><<
>>frame round<< Question 15:
Which one of the waveforms shows a typical waveform for the collector-emitter voltage of an NPN transistor used in a simple common-emitter amplifier circuit operating from a 10V supply?
(a) Waveform (a)
(b) Waveform (b)
>>id=example15 class=question margin=10px frame round<< Answer: A >><<
>>frame round<< Question 16:
In the circuit shown, the output voltage will consist of:
(a) a steady DC voltage of about 12V
(b) a steady DC voltage of about 17V
(c) a series of half-cycle pulses >><<
>>id=example16 class=question margin=10px frame round<< Answer: C >><<
>>frame round<< Question 17:
(a) 4.5V
(b) 9V
(c) 11.5V >><<
>>id=example17 class=question margin=10px frame round<< Answer: C >><<
>>frame round<< Question 18:
The device shown is:
(a) a timer
(b) a logic gate
(c) an operational amplifier >><<
>>id=example18 class=question margin=10px frame round<< Answer: C >><<
>>frame round<< Question 19:
The circuit shows a power supply based on a:
(a) half-wave rectifier
(b) full-wave rectifier
(c) bridge rectifier >><<
>>id=example19 class=question margin=10px frame round<< Answer: A >><<
>>frame round<< Question 20:
(a) 4.5V
(b) 9V
(c) 11.5V >><<
>>id=example20 class=question margin=10px frame round<< Answer: C >><<
>>frame round<< Question 21:
In the circuit shown, which component provides base bias current?
(a) C1
(b) R1
(c) R2 >><<
>>id=example21 class=question margin=10px frame round<< Answer: B >><<
>>frame round<< Question 22:
(a) Waveform (a)
(b) Waveform (b)
>>id=example22 class=question margin=10px frame round<< Answer: C >><< (:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 01:34 PM
