Recent Changes - Search:
<^< Multiple Choice Quiz: Active Circuits | Course index | Assignment: Active Circuits >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits ## Multiple Choice Quiz: Active Circuits ##
Written Questions: Active Circuits ## Assignment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Multiple Choice Quiz: Active Circuits | Course Index | Assignment: Active Circuits >^>(:nl:)
The section on the right contains a list of written questions. These can be printed out for your own use.
1. Sketch the circuit diagram of a simple single-stage transistor amplifier. Label your diagram clearly. State the function of each component used and give typical values.
2. Sketch the circuit diagram of a simple power supply using half-wave rectification. Label your diagram clearly. State the function of each component used and give typical values.
3. Sketch the circuit diagram of a simple power supply using full-wave rectification. Label your diagram clearly. State the function of each component used and give typical values.
4. Sketch a typical set of waveforms for a low-voltage DC power supply that uses half-wave rectification. Your waveforms should show:
(a) the voltage developed across the transformer secondary winding
(b) the voltage developed across the reservoir capacitor
(c) the voltage present at the output of the power supply.
Label your diagrams clearly.
5. With the aid of a labelled diagram, explain the action of a full-wave bridge rectifier.
6. A transistor switching circuit is to use an NPN silicon transistor having a common-emitter current gain, h'_FE_', of 40, a supply voltage of 10 V and a load resistance of 500 W.
(a) Sketch a labelled circuit diagram for the circuit(:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 01:34 PM
