Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals ## Multiple Choice Quiz: Fundamentals ## Written Questions: Fundamentals ## Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Assignment: Fundamentals<^< Written Questions: Fundamentals | Course Index | Introduction: Passive Components >^>(:nl:) The section bellow contains an assignment for you to complete. This can be printed out for your own use. An electronic test equipment manufacturer has asked you to assist with the development of a simple "go"/"no-go" electronic component tester. The component tester is to be able to detect the following fault conditions:
The tester is to be fitted with a battery, two terminals (to which the component under test is to be connected), and a small low-voltage filament lamp. #Sketch the circuit of the tester. Label the circuit clearly. #Suggest, with reasons, suitable ratings for the battery and filament lamp. #Explain how the circuit works and how it is possible to distinguish between faulty and functional components. #Produce a simple user's guide to the component tester and the indications that it provides. (:nl:)(:table style="clear:both":)
Page last modified on July 22, 2011, at 08:49 AM
