Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals ## Multiple Choice Quiz: Fundamentals ## Written Questions: Fundamentals ## Assignment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Multiple choice quiz: Fundamentals<^< Assessment: Fundamentals | Course Index | Written Questions: Fundamentals >^>(:nl:) >>frame round<< Question 1: An alternating current has a frequency of 2 kHz. Which one of the following gives the time for one complete cycle? (a) 0.5 ms >>id=example1 class=question margin=10px frame round<< Answer: A >><< >>frame round<< Question 2: Potential difference is measured in: (a) amps >>id=example2 class=question margin=10px frame round<< Answer: C >><< >>frame round<< Question 3: How many radians are there in 360°? (a) 2 >>id=example3 class=question margin=10px frame round<< Answer: C >><< >>frame round<< Question 4: A current of 2 A flows in a resistor of 6 Ω. Which one of the following gives the potential difference that appears across the resistor? (a) 0.33 V >>id=example4 class=question margin=10px frame round<< Answer: C >><< >>frame round<< Question 5: An electric field will appear between the plates of a capacitor when: (a) the plates are shorted together >>id=example5 class=question margin=10px frame round<< Answer: B >><< >>frame round<< Question 6: The prefix n is equivalent to a multiplier of: (a) 10'^-6^' >>id=example6 class=question margin=10px frame round<< Answer: B >><< >>frame round<< Question 7: A battery of 24 V is connected across an unknown resistance. If a current of 0.5 A is supplied, which one of the following gives the value of the resistor? (a) 6 Ω >>id=example7 class=question margin=10px frame round<< Answer: C >><< >>frame round<< Question 8: A solenoid consists of turns of wire wound on an iron core. The strength of the magnetic flux produced in the core depends: (a) only on the number of turns >>id=example8 class=question margin=10px frame round<< Answer: C >><< >>frame round<< Question 9: The prefix m is used to denote: (a) mega >>id=example9 class=question margin=10px frame round<< Answer: C >><< >>frame round<< Question 10: Provided temperature does not vary, Ohm's Law states that: (a) the product of potential difference to current flowing will be constant >>id=example10 class=question margin=10px frame round<< Answer: B >><< >>frame round<< Question 11: The peak value of an alternating voltage is 100 V. Which one of the following gives the average value of the voltage measured over one complete cycle? (a) 0 V >>id=example11 class=question margin=10px frame round<< Answer: A >><< >>frame round<< Question 12: In electrical circuits energy can be supplied by: (a) resistors and capacitors >>id=example12 class=question margin=10px frame round<< Answer: C >><< >>frame round<< Question 13: Electric current is measured in: (a) amps >>id=example13 class=question margin=10px frame round<< Answer: A >><< >>frame round<< Question 14: Which one of the following gives the units of electric charge? (a) Coulomb >>id=example14 class=question margin=10px frame round<< Answer: A >><< >>frame round<< Question 15: Electromotive force (e.m.f.) is provided by: (a) a battery >>id=example15 class=question margin=10px frame round<< Answer: A >><< >>frame round<< Question 16: In terms of the fundamental SI units, which one of the following gives the units of electric charge? (a) Ampere seconds (A s) >>id=example16 class=question margin=10px frame round<< Answer: A >><< >>frame round<< Question 17: The prefix k is equivalent to a multiplier of: (a) 10'^2^' >>id=example17 class=question margin=10px frame round<< Answer: B >><< >>frame round<< Question 18: Which one of the following is TRUE? (a) like charges repel one another >>id=example18 class=question margin=10px frame round<< Answer: A >><< >>frame round<< Question 19: Which one of the following gives the units of electric power? (a) Joule >>id=example19 class=question margin=10px frame round<< Answer: C >><< >>frame round<< Question 20: The symbol L is used to denote (a) capacitance >>id=example20 class=question margin=10px frame round<< Answer: B >><< >>frame round<< Question 21: The symbol used to denote charge in an electrical circuit is: (a) C >>id=example21 class=question margin=10px frame round<< Answer: C >><< >>frame round<< Question 22: An alternating current has 50 complete cycles in each second. Which one of the following gives the frequency of the current? (a) 25 Hz >>id=example22 class=question margin=10px frame round<< Answer: B >><< >>frame round<< Question 23: A magnetic field surrounding a wire can be detected by means of: (a) a compass >>id=example23 class=question margin=10px frame round<< Answer: A >><< >>frame round<< Question 24: One radian is approximately equal to: (a) 57° >>id=example24 class=question margin=10px frame round<< Answer: A >><< >>frame round<< Question 25: Electrons are: (a) negative charge carriers orbiting the nucleus of an atom >>id=example25 class=question margin=10px frame round<< Answer: A >><< (:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 10:12 AM
