Recent Changes - Search:
<^< Multiple Choice Quiz: Fundamentals | Course index | Assignment: Fundamentals >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals ## Multiple Choice Quiz: Fundamentals ##
Written Questions: Fundamentals ## Assignment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Multiple Choice Quiz: Fundamentals | Course Index | Assignment: Fundamentals >^>(:nl:)
The section below contains a list of written questions. These can be printed out for your own use.
1. Complete the following table of fundamental units:
QuantityUnitAbbreviation
current A
lengthmetre
candela cd
mass kg
temperaturedegree Kelvin
time s
matter mol
2. Express each of the following derived units in terms of the seven fundamental units:
(a) Charge in Coulomb, C
(b) Frequency in Hertz, Hz
(c) Potential in Volt, V
(d) Power in Watt, W
(e) Resistance in Ohm, &#937;.
3. State and define the units of (a) electrical potential and (b) electric current.
4. Complete the following table of multiples and sub-multiples:
PrefixAbbreviationMultiplier
gigaG
 M1,000,000
 k1,000
millim0.001
micro 0.000001
 n0.000000001
5. Convert each of the following:
(a) 0.657 MHz to kHz
(b) 0.0115 V to mV
(c) 42,500 &#937; to k&#937;
(d) 0.825 M&#937; to k&#937;
(e) 3,750 µH to µH
(f) 15,000 pF to nF
(g) 315° to radians
(h) 1.25 radians to °
6. State Ohm's Law.
7. A current of 15 mA flows in a resistor of 470 &#937;. What voltage drop will appear across the resistor?
8. A current of 50 mA flows in a resistor when connected to a 9 V supply. What is the value of the resistance?
9. A 9 V battery supplies a current of 300 mA. What power is supplied by the battery?
10. A resistor is rated at 100 &#937;, 0.4 W. What is the maximum current and voltage that can safely be applied to this resistor?
11. Complete the following sentences:
(a) "Magnetic field lines may be constructed by following the path of a ___________________ moving within the field".
(b) "Electric field lines may be constructed by following the path of a ___________________ moving within the field".
12. A sinusoidal alternating voltage has a peak value of 25 V and a frequency of 50 Hz. Sketch a graph showing TWO cycles of the waveform and label the axes of voltage and time indicating values in each case.
13. Explain what is meant by: (a) capacitance and (b) inductance.
14. A current changes from 100 mA to 200 mA in a time interval of 10 ms. What voltage will be induced in a 1.5 H inductor when this current is applied to it?
15. A voltage changes from 10 V to 50 V in a time interval of 0.02 s. What current will be flow in a 10µF capacitor when this voltage is applied to it? (:nl:)(:table style="clear:both":)
Page last modified on July 19, 2011, at 09:16 AM
