Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits ## Multiples Choice Quiz: Passive Circuits ## Written Questions: Passive Circuits ## Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Assignment: Passive Circuits<^< Written Questions: Passive Circuits | Course Index | Introduction: Active Circuits >^>(:nl:) The section bellow contains an assignment for you to complete. This can be printed out for your own use. ![]() A simple timing circuit is shown in the figure. At time t = 0 the switch is moved from position 2 to position 1. The switch is then left in position 1 until t = 4 s and then moved to position 2. Assuming that the capacitor, C, is initially uncharged, sketch graphs that show: # How the voltage developed across the capacitor varies with time over the range t = 0 to t = 10 s. # How the current flowing in the capacitor varies with time over the range t = 0 to t = 10 s. # Label your graphs clearly. (:nl:)(:table style="clear:both":)
Page last modified on July 25, 2011, at 12:37 PM
