Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components ## Multiple Choice Quiz: Passive Components ## Written Questions: Passive Components ## Assignment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Assignment: Passive Components<^< Written Questions: Passive Components | Course Index | Introduction: Semiconductors >^>(:nl:) The section below contains an assignment for you to complete. This can be printed out for your own use. An electronic component manufacturer has asked you to advise on a new range of resistors. The resistors are to be manufactured in the E12 series with values from 1 Ω to 100 Ω and are to be rated at 2.5 W maximum with a tolerance of 10%. The company has asked you to provide answers to the following questions: # List the resistance values that are to be manufactured. # What is the maximum voltage that can be applied to the 1 Ω resistor? # What is the maximum current that can be applied to the 100 Ω resistor? # What range of possible values can a 10 Ω resistor have? # What colour coding should be applied to the resistors? # The resistors are to be manufactured using a material that has a low temperature coefficient. Explain why this is a desirable feature. (:nl:)(:table style="clear:both":)
Page last modified on August 15, 2011, at 02:49 PM
