Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors ## Inductor Specifications ## Preferred Values: Inductors ## Inductor Markings ## Examples: Inductor Markings ## Inductor Symbols ## Inductor Construction ## Inductors in Series ## Inductors in Parallel ## Examples: Inductors in Circuits ## Variable Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Examples: Inductor Markings<^< Inductor Markings | Course Index | Inductor Symbols >^>(:nl:) >>frame round<< Example 1: A ferrite cored inductor is marked with the legend '471K'. What is its value? >><<
>>id=example1 class=question margin=10px frame round<< The value (in µH) will be given by the first two digits (47) followed by the number of zeros indicated by the third digit (1). The value of the inductor is thus 470µH. The final letter (K) indicates that the inductor has a tolerance of 10%. >><< >>frame round<< Example 2: A circuit requires an inductor of 68µH with a tolerance of 5%. What is it likely to be marked? >><<
>>id=example2 class=question margin=10px frame round<< The marking (in µH) will show the first two digits (68) followed by the number of zeros (0). Since the tolerance is 5%, the final letter should be J. Thus the marking should be '680J'. >><<(:nl:)(:table style="clear:both":)
Page last modified on July 21, 2011, at 09:31 AM
