Recent Changes - Search:
<^< Examples: Inductors in Circuits | Course index | Transformers >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors ## Inductor Specifications ## Preferred Values: Inductors ## Inductor Markings ## Examples: Inductor Markings ## Inductor Symbols ## Inductor Construction ## Inductors in Series ## Inductors in Parallel ## Examples: Inductors in Circuits ##
Variable Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
Variable Inductors
<^< Examples: Inductors in Circuits | Course Index | Transformers >^>(:nl:)
By moving the magnetic core of an inductor in and out of the inductor windings, an inductor can be made variable. A ferrite cored inductor can be made variable by moving its core in or out of the former onto which the coil is wound. Many small inductors have threaded ferrite cores to make this possible. Such inductors are often used in radio and high-frequency applications where precise tuning is required. Typical values for variable inductors tend to range from about 10&#956;H to 100&#956;H.
Finally, you may also encounter various forms of preset inductor that are used to make occasional adjustments (e.g. for precisely adjusting the frequency of an oscillator). Typical values for preset inductors tend to range from about 10nH to 100mH. (:nl:)(:table style="clear:both":)
Page last modified on July 21, 2011, at 08:18 AM
