Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws ## Kirchoff's Current Law ## Examples: Kirchoff's Current Law ## Worksheet: Kirchoff's Current Law ## Kirchoff's Voltage Law ## Examples: Kirchoff's Voltage Law ## Worksheet: Kirchoff's Voltage Law * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Examples: Kirchoff's Voltage Law<^< Kirchoff's Voltage Law | Course Index | Worksheet: Kirchoff's Voltage Law >^>(:nl:) >>frame round<< Example 1: Determine the voltage drop across R1 and the current flowing in it. ![]() >><<
>>id=example1 class=question margin=10px frame round<< The Kirchhoff's Voltage Law equation for this circuit is: +V'_R1_' + E2 - E3 - E1 = 0 hence: V'_R1_' = E3 + E1 - E2 = 1.5 + 6 - 3 = 4.5 V We can now use Ohm's Law to determine the current in R1 from: I = V'_R1_' / R1 = 4.5 / 90 = 0.05 A = 50 mA >><< >>frame round<< Example 2: Determine the value of V'_X_' and the current flowing in R1. ![]() >><<
>>id=example2 class=question margin=10px frame round<< The Kirchhoff's Voltage Law equation for this circuit is: +45 - V'_X_' - 12 - 18 = 0 hence: V'_X_' = 45 - 12 - 18 = 45 - 30 = 15 V We can now use Ohm's Law to determine the current in R1 from: I = V'_X_' / R1 = 15 / 7.5 = 2 A >><<(:nl:)(:table style="clear:both":)
Page last modified on July 25, 2011, at 10:01 AM
