Recent Changes - Search:
<^< Worksheet: Kirchoff's Current Law | Course index | Examples: Kirchoff's Voltage Law >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws ## Kirchoff's Current Law ## Examples: Kirchoff's Current Law ## Worksheet: Kirchoff's Current Law ##
Kirchoff's Voltage Law ## Examples: Kirchoff's Voltage Law ## Worksheet: Kirchoff's Voltage Law * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Worksheet: Kirchoff's Current Law | Course Index | Examples: Kirchoff's Voltage Law >^>(:nl:)
Kirchhoff's Voltage Law states that the algebraic sum of the potential drops in a closed network (or mesh) is zero. Here again, the term "algebraic" simply indicates that the polarity of each voltage drop as you move around the closed mesh must be taken into account by giving it an appropriate sign, either positive (+) or negative (-).
Convention: *Start at the positive terminal of the largest EMF and move clockwise around the circuit. *Voltages acting in the same direction as you move around the circuit are positive(+). *Voltages acting in the opposite direction as you move around the circuit are negative(-). (:nl:)(:table style="clear:both":)
Page last modified on July 25, 2011, at 09:55 AM
