Recent Changes - Search:
<^< NOR Gates | Course index | Exclusive-NOR Gates >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates ## AND Switch ## OR Switch ## Buffers ## Inverters ## AND Gates ## OR Gates ## NAND Gates ## NOR Gates ##
Exclusive-OR Gates ## Exclusive-NOR Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
Exclusive OR Gates
<^< NOR Gates | Course Index | Exclusive-NOR Gates >^>(:nl:)
Exclusive-OR gates will produce a logic 1 output whenever either one of the inputs is at logic 1 and the other is at logic 0. Exclusive-OR gates produce a logic 0 output whenever both inputs have the same logical state (i.e., when both are at logic 0 or both are at logic 1). The Boolean expression for the output, Y, of an exclusive-OR gate with inputs, A and B, is:
Y = A . + B .
>>id=box1 class=toggle center<<
>><< >>id=box2 class=toggle center<<
>><< >>id=box3 class=toggle center<<
>><< >>id=box4 class=toggle center<<
Logic 0, Logic 0
Logic 0, Logic 1
Logic 1, Logic 0
Logic 1, Logic 1
(:nl:)(:table style="clear:both":)
Page last modified on July 25, 2011, at 08:28 AM
