input pullups - ARM processor, STM32f0..
Harvolt
Has thanked: 2 times
Been thanked: 3 times
Post by Harvolt »
hi all,
is there a convenient way, either graphically or C code to implement a pull up on a digtial input for STM32f0 processors? :?:
Has thanked: 289 times
Been thanked: 457 times
Re: input pullups - ARM processor, STM32f0..
I am not familiar with that range of devices, but looking at the datasheet there is a register that controls the internal weak pull-ups and pull-downs for the I/O ports (GPIOx_PUPDR).
Harvolt
Post by Harvolt »
so will the flowcode IDE support a discrete C code write to this register via a Code Command icon? will the compiler understand or recognise that register name?
Could you provide an example of how this would be done? - i purchased the FLOWCODE ARM version for training only,i was hoping this would be straighforward, before i consider purchasing a professional license.
Has thanked: 615 times
Been thanked: 811 times
This reply on our old forum might be useful for you.
https://www.flowcode.co.uk/mmforums/view ... 272#p92272
LeighM
Has thanked: 103 times
Been thanked: 302 times
Post by LeighM »
To simplify the C code, add these definitions into the Project Options -> Supplementary Code -> Definitions
#define PULL_UP(port, pin) GPIO##port->PUPDR |= (1 << (pin *2))
#define PULL_DOWN(port, pin) GPIO##port->PUPDR |= (2 << (pin *2))
Then, as an example, to turn on pullup to port B pin 8, add this into a C icon
PULL_UP(B, 8);
nb. You will still need to use C code to read the pin, as mentioned in the post linked by Ben.
Hope that helps.
Harvolt
Post by Harvolt »
hi Ben, Steve, Leigh,
thanks for getting back - got a chance now to give this a go..
