Ribbon Toolbar
Revision as of 09:13, 11 June 2013 by ReeceL (talk | contribs)
<sidebar>Sidebar: Getting Started</sidebar> The Flowcode environment consists of a main work area in which the flowchart windows are displayed, several toolbars that allow icon and components to be added to the flowchart application, windows that allow the status of the microcontroller and attached components to be viewed and windows that display variables and macro calls when the flow chart is being simulated.
1) Icons Toolbar
File:Icons Toolbar Undocked.png
2) Components Toolbar
This toolbar displays the external components that can be connected to a microcontroller. Click on a component and it will be added to the microcontroller in the Microcontroller view. The pin connections and properties of the component can then be edited.
File:Components Toolbar Undocked.png
Docking and Undocking the Toolbars
File:Chip View.png
Chip / Microcontroller View
File:Eg Tools and views Grab Bar Area.png
3) Chip View
4) Flowchart Window
System Panel
5) System Panel
6) Dashboard Panel
Project Explorer
7) Project Explorer
Icon Lists Pane
8) Icon Lists
9) Simulation Debugger
Simulation Debugger
10) Main Toolbar
Use this command to display and hide the Toolbar, which includes buttons for some of the most common commands in Flowcode, such as File Open. There are also buttons for starting, stopping and pausing the simulation on the toolbar.
11) Status Bar
12) Current Zoom Level
The currently selected Zoom level is displayed on the right side of the Status Bar.
