Components
Revision as of 15:44, 9 August 2013 by JonnyW (talk | contribs) (XML import of component lists)
MIAC Module
Image MIAC TODO: Desc,Examples,DLMacros,SimMacros
Image MIAC USB Slave TODO: Desc,Examples
Controls
Image Bar meter TODO: Examples,SimMacros
Image Button helper TODO: Examples,Properties
Image COM Port TODO: Examples,SimMacros,Properties
Image Dashboard Text TODO: Examples,Properties
Image Dial control TODO: Examples
Image FCD helper TODO: Desc,Examples
Image LCD control TODO: Examples,SimMacros,Properties
Image MIAC Keypad TODO: Desc,Examples,SimMacros
Image Marking control TODO: Examples,SimMacros
Image Panel Console Viewer TODO: Examples,Properties
Image Scale Arc TODO: Examples
Image Scale_Linear TODO: Examples
Image Simulation LED TODO: Examples,Properties
Image Simulation Switch TODO: Examples
Image Slider control TODO: Examples,SimMacros
Image Texture scroll TODO: Examples
Comms
Image CAN TODO: Examples,DLMacros,SimMacros,Properties
Image Data Injector TODO: Desc,Examples,SimMacros
Image I2C Master TODO: Desc,Examples,DLMacros,Properties
Image IrDA TODO: Desc,Examples,DLMacros,Properties
Image LIN Master TODO: Desc,Examples,DLMacros,Properties
Image LinSlave TODO: Desc,Examples,Properties
Image MIDI TODO: Desc,Examples,DLMacros,Properties
Image One Wire TODO: Desc,Examples,DLMacros,Properties
Image RS232 TODO: Desc,Examples,DLMacros,Properties
Image SPI Legacy TODO: Desc,Examples,DLMacros,Properties
Image TCP Base TODO: Desc,Examples,Properties
Image USB HID TODO: Desc,Examples,DLMacros,Properties
Image USB Serial TODO: Desc,Examples
Image USB Slave TODO: Desc,Examples,Properties
Wireless
Image Bluetooth TODO: Desc,Examples,DLMacros,Properties
Image GPS TODO: Desc,Examples,Properties
Image GSM TODO: Desc,Examples,DLMacros,Properties
Image RC5 TODO: Desc,Examples,DLMacros,Properties
Image RF ISM TODO: Desc,Examples,DLMacros,Properties
Image RFID TODO: Desc,Examples,DLMacros,Properties
Image WLAN TODO: Desc,Examples,DLMacros,Properties
Image Zigbee TODO: Desc,Examples,DLMacros,Properties
Inputs
Image ADC base TODO: Examples,SimMacros,Properties
Image Collision Detector TODO: Examples,Properties
Image Keypad Base TODO: Examples,Properties
Image Switch Array TODO: Examples
Image Switch base TODO: Examples
Outputs
Image 7 Segment Quad TODO: Examples
Image 7 Segment Single TODO: Examples
Image Analogue LED TODO: Examples
Image Dashboard Lamp TODO: Examples
Image GLCD base TODO: Desc,Examples,DLMacros
Image LCD TODO: Examples,Properties
Image LCD Adafruit OLED TODO: Examples,DLMacros,Properties
Image LED Array TODO: Examples
Image LED Base TODO: Examples
Image LED Matrix (Parallel) TODO: Desc,Examples,DLMacros,Properties
Image LED Matrix (Serial) TODO: Desc,Examples,DLMacros,Properties
Image Meter Square TODO: Examples
Image PWM TODO: Desc,Examples,DLMacros,Properties
Image RGB LED TODO: Examples,Properties
Image RxTx Flasher TODO: Examples
CAL
Image ADC TODO: Desc,Examples,SimMacros,Properties
Image CAPTOUCH TODO: Desc,Examples,DLMacros
Image EEPROM TODO: Desc,Examples,Properties
Image I2C TODO: Desc,Examples,DLMacros,Properties
Image PWM TODO: Desc,Examples,Properties
Image SPI TODO: Desc,Examples,DLMacros,SimMacros,Properties
Image UART TODO: Desc,Examples,SimMacros,Properties
Sound
Image Speech TODO: Desc,Examples,SimMacros,Properties
Misc
Image Bezel Radiused TODO: Examples
Image Clone Matrix TODO: Examples
Image E_block Helper TODO: Desc,Examples,Properties
Image Port Matrix TODO: Examples,Properties
Image Webserver EB023_00_1 TODO: Desc,Examples,DLMacros,Properties
Image Webserver EB023_00_2 TODO: Desc,Examples,DLMacros,Properties
Image panel TODO: Desc,Examples,Properties
Mechatronics
Image 3D Printer TODO: Examples,SimMacros,Properties
Image Accelerometer Compass EBM015 TODO: Desc,Examples,DLMacros,Properties
Image Accelerometer EB068 TODO: Desc,Examples,DLMacros,Properties
Image FTDI FTD2XX TODO: Desc,Examples,DLMacros
Image Formula Flowcode TODO: Desc,Examples,Properties
Image K8055D TODO: Examples
Image PS2000 TODO: Desc,Examples,DLMacros
Image Quad Encoder TODO: Examples,Properties
Image Servo Controller TODO: Examples
Image Servo Motor Base TODO: Examples
Image Solenoid Base TODO: Examples
Image Stepper motor base TODO: Examples
DSP
Image Control TODO: Desc,Examples,DLMacros,Properties
Image DSP Buffer Link TODO: Desc,Examples,Properties
Image DSP Dummy TODO: Desc,Examples,DLMacros
Image DSP System TODO: Examples,Properties
Image Delay TODO: Desc,Examples,DLMacros,Properties
Image FFT Inverse TODO: Desc,Examples,DLMacros,Properties
Image Fast Fourier Transform (FFT) TODO: Desc,Examples,DLMacros,Properties
Image Filter TODO: Desc,Examples,DLMacros,Properties
Image Frequency Generator TODO: Desc,Examples,DLMacros,Properties
Image Input TODO: Desc,Examples,DLMacros,SimMacros,Properties
Image Kalman Filter TODO: Desc,Examples,DLMacros,Properties
Image Level TODO: Examples
Image Output TODO: Examples
Image Scale TODO: Examples
Image Sum TODO: Examples
Storage
Image EEPROM TODO: Examples
Image FAT TODO: Examples,DLMacros,Properties
Image Lookup tables TODO: Examples,Properties
