Recent Changes - Search:
<^< Worksheet: Diode Characteristics | Course index | Examples: Zener Diodes >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes ## Operation ## Forward and Reverse Bias ## Diode Characteristics ## Worksheet: Diode Characteristics ##
Zener Diodes ## Examples: Zener Diodes ## Worksheet: Zener Diodes ## Light Emitting Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
Zener Diodes
<^< Worksheet: Diode Characteristics | Course Index | Examples: Zener Diodes >^>(:nl:)
'''Graph showing Zener diode characteristics'''
Zener diodes are heavily doped silicon diodes which, unlike normal diodes, exhibit an abrupt reverse breakdown at relatively low voltages (typically less than 6V). A similar effect occurs in less heavily doped diodes. These avalanche diodes also exhibit a rapid breakdown with negligible current flowing below the avalanche voltage and a relatively large current flowing once the avalanche voltage has been reached. For avalanche diodes, this breakdown voltage usually occurs at voltages above 6V. In practice, however, both types of diode are referred to as zener diodes. A typical characteristic for a 5.1V zener diode is shown.
Whereas reverse breakdown is a highly undesirable effect in circuits that use conventional diodes, it can be extremely useful in the case of zener diodes where the breakdown voltage is precisely known. When a diode is undergoing reverse breakdown, and provided its maximum ratings are not exceeded, the voltage appearing across it will remain substantially constant (equal to the nominal breakdown voltage or zener voltage) regardless of the current flowing. This property makes the zener diode ideal for use as a voltage reference or voltage regulator. (:nl:)(:table style="clear:both":)
Page last modified on July 22, 2011, at 09:14 AM
