Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits ## C-R Charging ## Worksheet: C-R Charging ## C-R Discharging ## Worksheet: C-R Discharging ## Passive Wave-shaping Circuits ## Worksheet: Passive Wave-shaping Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Passive Wave-shaping Circuits<^< Worksheet: C-R Discharging | Course Index | Worksheet: Passive Wave-shaping Circuits >^>(:nl:)
One of the most common applications of C-R networks is in simple filter and waveshaping circuits. The circuits shown function as simple square-to-triangle and square-to-pulse converters by respectively 'integrating' and 'differentiating' their inputs. The effectiveness of the integrator circuit depends very much upon the ratio of time constant (C x R) to periodic time (t). The larger this ratio is, the more effective the circuit will be as an integrator. Similarly, the effectiveness of the simple differentiator circuit also depends on the ratio of time constant (C x R) to periodic time (t). The smaller this ratio is, the more effective the circuit will be as a differentiator. (:nl:)(:table style="clear:both":)
Page last modified on July 25, 2011, at 10:32 AM
