Recent Changes - Search:
<^< Passive Wave-shaping Circuits | Course index | Assessment: Passive Circuits >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits ## C-R Charging ## Worksheet: C-R Charging ## C-R Discharging ## Worksheet: C-R Discharging ## Passive Wave-shaping Circuits ##
Worksheet: Passive Wave-shaping Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Passive Wave-shaping Circuits | Course Index | Assessment: Passive Circuits >^>(:nl:)
Objective: To investigate the action of a C-R waveshaping circuit.
Underpinning knowledge: Passive waveshaping circuits.
Apparatus: TINA circuit file, or apparatus to make the following circuit.
TINA Circuit File: Click here to download circuit file
Initial Settings: C = 1µF, R = 1k&#937; (integrating circuit), square wave source at 1kHz.
Requires: Paper, Linear graph paper, pen or pencil.
Instructions:
(a) Calculate the time constant of the circuit (C x R).
(b) Display two or three cycles of the input and output waveforms using a common time scale. Sketch these waveforms and include labelled axes of voltage and time.
(c) Repeat (a) and (b) with C = 10µF, C = 100µF, C = 100nF and C = 10nF.
(d) Reconnect the circuit as an integrating circuit (i.e. swap the capacitor and resistor over).
(e) Repeat steps (a) to (c).
Observations:
Comment on the waveforms produced by the circuit. What can you say about the effectiveness of each type of circuit in terms of the time constant (C x R) and the periodic time of the square wave input (1ms)?
Further work:
Construct an integrating circuit for use at 20kHz and a differentiating circuit for use at 50Hz. In both cases, use R = 10k&#937;. Select appropriate values of capacitor in each case and check the effectiveness of your circuits using your circuit simulation software.
(:nl:)(:table style="clear:both":)
Page last modified on July 28, 2011, at 01:50 PM
