Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits ## Half-wave rectifier ## Worksheet: Half-wave Rectifier ## Full-wave Rectifier ## Worksheet: Full-wave Rectifier ## Bridge Rectifier ## Worksheet: Bridge Rectifier ## Reservoir and Smoothing Circuit ## Worksheet: Reservoir and Smoothing Circuit ## Simple Power Supply ## Worksheet: Simple Power Supply * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Bridge Rectifier<^< Worksheet: Full-wave Rectifier | Course Index | Worksheet: Bridge Rectifier >^>(:nl:) ![]() An alternative form of full-wave rectifier is the bridge rectifier. This circuit uses four similar diodes in which opposite pairs conduct on alternate half-cycles. This arrangement avoids the need to have two separate secondary windings (as in the bi-phase rectifier circuit). On positive half-cycles, point A will be positive with respect to point B. In this condition D'_1_' and D'_2_' will allow conduction whilst D'_3_' and D'_4_' will not allow conduction. Conversely, on negative half-cycles, point B will be positive with respect to point A. In this condition D'_3_' and D'_4_' will allow conduction whilst D'_1_' and D'_2_' will not allow conduction. As with the bi-phase rectifier, the switching action of the two diodes results in a pulsating output voltage being developed across the load resistor, R'_L_'. (:nl:)(:table style="clear:both":)
Page last modified on July 25, 2011, at 01:28 PM
