Recent Changes - Search:
<^< Worksheet: Half-wave Rectifier | Course index | Worksheet: Full-wave Rectifier >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits ## Half-wave rectifier ## Worksheet: Half-wave Rectifier ##
Full-wave Rectifier ## Worksheet: Full-wave Rectifier ## Bridge Rectifier ## Worksheet: Bridge Rectifier ## Reservoir and Smoothing Circuit ## Worksheet: Reservoir and Smoothing Circuit ## Simple Power Supply ## Worksheet: Simple Power Supply * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
Full-wave Rectifier
<^< Worksheet: Half-wave Rectifier | Course Index | Worksheet: Full-wave Rectifier >^>(:nl:)
The half-wave rectifier circuit is relatively inefficient as conduction takes place only on alternate half-cycles. A better rectifier arrangement would make use of both positive and negative half-cycles. These full-wave rectifier circuits offer a considerable improvement over their half-wave counterparts. They are not only more efficient but are significantly less demanding in terms of the reservoir and smoothing components.
In the simple bi-phase rectifier circuit mains voltage is applied to the primary of a step down transformer which has two identical low-voltage secondary windings. The circuit works like this:
On positive half-cycles, the anode of D1 will be positive with respect to its cathode and it will conduct rather like a closed switch. The anode of D'_2_', on the other hand, will be negative with respect to its cathode and it will behave like an open switch. Thus a positive half-cycle of current will be supplied to the load, R'_L_', through D'_1_'.
On negative half-cycles, the anode of D'_2_' will be positive with respect to its cathode and it will conduct rather like a closed switch. The anode of D'_1_', on the other hand, will be negative with respect to its cathode and it will behave like an open switch. Once again, a positive half-cycle of current will be supplied to the load, R'_L_', but this time it will flow through D'_2_'. (:nl:)(:table style="clear:both":)
Page last modified on July 25, 2011, at 01:20 PM
