Recent Changes - Search:
<^< Waveforms and Signals | Course index | Examples: Amplitude and Frequency >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current ## Alternating Voltage and Current ## Waveforms and Signals ##
Amplitude and Frequency ## Examples: Amplitude and Frequency ## Measuring Angles ## Radians ## Examples: Radians ## Average Peak and RMS Values ## Reactance ## Capacitive Reactance ## Worksheet: Capacitive Reactance ## Inductive Reactance ## Worksheet: Inductive Reactance ## Impedance ## Worksheet: Impedance * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Waveforms and Signals | Course Index | Examples: Amplitude and Frequency >^>(:nl:)
The amplitude (or peak value) of a waveform is a measure of the extent of its voltage or current excursion from the resting value (usually zero). The peak-to-peak value for a wave which is symmetrical about its resting value is twice its peak value.
The frequency of a repetitive waveform is the number of cycles of the waveform which occur in unit time. Frequency is expressed in Hertz (Hz). A frequency of 1Hz is equivalent to one cycle per second. Hence, if a voltage has a frequency of 400Hz, 400 cycles will occur in every second.
The periodic time of a waveform is the time taken for one complete cycle of the wave. The relationship between periodic time and frequency is thus:
t = 1/f or f = 1/t
where t is the periodic time, in seconds and f is the frequency, in Hz.
The equation for the sinusoidal voltage shown at a time, t, is:
v = V'_max_' sin(&#969;t)
where v is the instantaneous voltage, V'_max_' is the amplitude (or peak) voltage, and &#969; is the angular speed of the wave (in radians per second).
Since one complete rotation of the wave (i.e. 360º) is equivalent to 2&#960; radians we can deduce that:
&#969; = 2&#960;f
where f is the frequency of the wave in Hertz.
The images below allows you to see the relationship between waveform frequency, amplitude and the mathematical representation of the waveform.
>>id=box1 class=toggle center<<
Wave at 100hz and 1 amplitude
'''v = 1sin(2&#960;x100t)'''
>><< >>id=box2 class=toggle center<<
Wave at 1000hz and 1 amplitude
'''v = 1sin(2&#960;x1000t)'''
>><< >>id=box3 class=toggle center<<
Wave at 500hz and 1 amplitude
'''v = 1sin(2&#960;x500t)'''
>><< >>id=box4 class=toggle center<<
Wave at 500hz and 0.1 amplitude
'''v = 0.1sin(2&#960;x500t)'''
(:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 10:00 AM
