Recent Changes - Search:
<^< Alternating Voltage and Current | Course index | Amplitude and Frequency >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current ## Alternating Voltage and Current ##
Waveforms and Signals ## Amplitude and Frequency ## Examples: Amplitude and Frequency ## Measuring Angles ## Radians ## Examples: Radians ## Average Peak and RMS Values ## Reactance ## Capacitive Reactance ## Worksheet: Capacitive Reactance ## Inductive Reactance ## Worksheet: Inductive Reactance ## Impedance ## Worksheet: Impedance * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Alternating Voltage and Current | Course Index | Amplitude and Frequency >^>(:nl:)
The shape of a signal's waveform determines its quality. The most fundamental waveform is a sine wave. This is often referred to as a pure tone. Other waves are rich in harmonics and these give them their own particular quality. In addition, signals can be modulated. This is the name given to a process whereby one wave is used to vary the properties of another. With amplitude modulation, AM, a low frequency signal is used to vary the amplitude of another signal at a much higher frequency. With frequency modulation, FM, a low frequency signal is used to vary the frequency of another signal at a much higher frequency. The virtual laboratory will let you see a few types of common waveforms.
>>id=box1 class=toggle center<<
Diagram of a sinewave
'''Sine waveform'''
>><< >>id=box2 class=toggle center<<
Diagram of an amwave
'''AM waveform'''
>><< >>id=box3 class=toggle center<<
Diagram of a fmwave
'''FM waveform'''
Sine waveform
AM waveform
FM waveform
(:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 09:56 AM
