Recent Changes - Search:
<^< Inductive Reactance | Course index | Impedance >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current ## Alternating Voltage and Current ## Waveforms and Signals ## Amplitude and Frequency ## Examples: Amplitude and Frequency ## Measuring Angles ## Radians ## Examples: Radians ## Average Peak and RMS Values ## Reactance ## Capacitive Reactance ## Worksheet: Capacitive Reactance ## Inductive Reactance ##
Worksheet: Inductive Reactance ## Impedance ## Worksheet: Impedance * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Inductive Reactance | Course Index | Impedance >^>(:nl:)
Objective: To investigate the action of an inductor when connected to an a.c. supply.
Underpinning knowledge: Alternating current and voltage. Inductance. Reactance. Ohm's Law.
Apparatus: TINA circuit file, or apparatus to make the following circuit.
TINA Circuit File: Click here to download circuit file
Initial Settings: L = 10mH, a.c. supply of 10V at 100Hz
Requires: Paper, Linear graph paper, pen or pencil.
Instructions:
(a) Using initial settings determine X'_L_' from X'_L_' = V/I.
(b) Calculate X'_L_' from X'_L_' = 2&#960; f L.
(c) Compare the results from (a) and (b) (they should be the same!)
(d) Vary the frequency of the a.c. supply from 100Hz to 10kHz (we suggest that you use the following values: 100Hz, 200Hz, 400Hz, 1kHz, 2kHz, 4kHz, and 10kHz) and, at each frequency, measure and record the current flowing in a table.
(e) Determine the reactance, X'_L_', at each frequency in (d).
(f) Plot a graph of reactance, X'_L_', against frequency, f, using the data from (e).
Observations:
Confirm that, X'_L_' = V/I = 2&#960; f L. Comment on the shape of the graph. Does inductive reactance increase or decrease with frequency?
Further work:
Determine the value of inductance that would exhibit a reactance of 100&#937; at 1kHz.
(:nl:)(:table style="clear:both":)
Page last modified on July 27, 2011, at 03:04 PM
