Recent Changes - Search:
<^< Batteries | Course index | Internal Resistance >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches ## Batteries ##
Examples: Batteries ## Internal Resistance ## Examples: Internal Resistance ## Fuses ## Lamps ## Switches ## Switch Types * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
Examples: Batteries
<^< Batteries | Course Index | Internal Resistance >^>(:nl:)
>>frame round<< Example 1:
A lead acid battery comprises six series-connected 2V cells . If the battery is rated at 12 Ah (and assuming that the battery is fully charged), determine the terminal voltage of the battery and the current that it should deliver for a period of 4 hours. >><<
>>id=example1 class=question margin=10px frame round<< The terminal voltage of the battery will be 6 x 2 V or 12 V. The current that the battery should provide during a 4 hour discharge period will be given by (12 / 4) A or 3 A. >><<
>>frame round<< Example 2:
A nickel cadmium battery comprises ten individual series-connected cells (each having a nominal discharge voltage of 1.2V). If the battery is rated at 4.8 Ah at the 6 hour discharge rate, determine the terminal voltage of the battery and its energy content. >><<
>>id=example2 class=question margin=10px frame round<< The terminal voltage of the battery will be 10 x 1.2 V or 12 V. The energy content of the battery will be given by:
Energy content = 4.8 Ah x 12 V = 57.6 Wh >><<(:nl:)(:table style="clear:both":)
Page last modified on July 21, 2011, at 09:45 AM
