Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches ## Batteries ## Examples: Batteries ## Internal Resistance ## Examples: Internal Resistance ## Fuses ## Lamps ## Switches ## Switch Types * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Internal Resistance<^< Examples: Batteries | Course Index | Examples: Internal Resistance >^>(:nl:) ![]() All sources of voltage (or e.m.f.) have a certain amount of resistance inside them. This resistance limits the amount of current that a source of voltage can supply. Because the resistance appears to be inside the voltage source we refer to it as "internal resistance". With a large battery, such as a 12V lead-acid car battery, the internal resistance is very small (typically a fraction of an ohm). On the other hand, a small 1.5V dry cell will usually have an internal resistance of a few ohms. Like the lead-acid battery, this resistance increases as the battery becomes exhausted (or goes "flat"). Because we can't actually see the resistance (remember that it's hidden inside the voltage source) this doesn't mean that it's unimportant. If we need a voltage source that can deliver a large value of current we need to ensure that its internal resistance is as small as possible. A perfect voltage source would have zero internal resistance. To consider the effect of internal resistance on the output voltage of a real battery, we can think of the battery as being a perfect voltage source connected in series with a resistor equal to its internal resistance, as shown in the diagram. The voltage that appears at the battery terminals is less than the voltage produced by the voltage source by an amount equal to the voltage dropped across the internal resistance. Hence the output voltage produced by the battery when connected to a load of R ohms is given by: V'_OUT_' = V - (I x R'_S_') where I is the current flowing in the load, and R'_S_' is the internal resistance. Finally, it's worth noting that, when a battery is not supplying any current at all (i.e. when no load is connected to it), its terminal voltage, V'_OUT_', will be the same as its internal voltage, V. However, when a load is connected to the same battery (and current is drawn from it) its terminal voltage will fall. (:nl:)(:table style="clear:both":)
Page last modified on July 21, 2011, at 02:56 PM
