Recent Changes - Search:
<^< Switches | Course index | Assessment: Passive Components >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches ## Batteries ## Examples: Batteries ## Internal Resistance ## Examples: Internal Resistance ## Fuses ## Lamps ## Switches ##
Switch Types * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Switches | Course Index | Assessment: Passive Components >^>(:nl:)
>>frame round<< Single-pole, Single-throw
The single-pole, single-throw (SPST) switch functions as a basic single-circuit 'on'/'off' switch.
>>frame round<< Single-pole, Double-throw
The single-pole, double-throw (SPDT) switch functions as a single-circuit two-way switch. This type of switch is sometimes referred to as a single-pole changeover switch.
>>frame round<< Double-pole, Single-throw
The double-pole, single-throw switch functions as a two-circuit 'on'/'off' switch.
>>frame round<< Double-pole, Double-throw
The double-pole, double-throw switch functions as a two-circuit two-way switch. This type of switch is sometimes referred to as a double-pole changeover switch.
>>frame round<< Multi-pole, Multi-way
Complex circuits may require switches that can switch more than two ways or have more than two poles. These switches are called multi-pole, multi-way switches.
Commonly available types include:
* Two-pole, three-way (2P 3W) * Four-pole, two-way (4P 2W) * Three-pole, four-way (3P 4W) * Four-pole, three-way (4P 3W) * Two-pole, six-way (2P 6W) * One-pole, twelve-way (1P 12W)
>>frame round<< Push-button Switches
Push-button switches (which may be either momentary or latching types) are available in normally open (NO) or normally closed (NC) types. The contacts of a normally open switch become closed when the switch is operated while those of a normally closed switch become opened when the switch is operated.
>><<(:nl:)(:table style="clear:both":)
Page last modified on July 21, 2011, at 10:05 AM
