Recent Changes - Search:
<^< Examples: Current Flow Model | Course index | Worksheet: Transistor as a Current Amplifier >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors ## Transistor Construction ## Transistor Symbols and Connections ## Transistor Operation ## Current flow Model ## Examples: Current Flow Model ##
Transistor as a Current Amplifier ## Worksheet: Transistor as a Current Amplifier ## Transistor as a Switch * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Examples: Current Flow Model | Course Index | Worksheet: Transistor as a Current Amplifier >^>(:nl:)
In a simple transistor amplifier the collector current (IC) is related to the base current (IB) by the formula:
h'_FE_' = I'_C_'/I'_B_'
where h'_FE_' is the current gain (in common emitter mode).
Thus, if a small current is applied to the base of a transistor, the collector current will be h'_FE_' times larger. For example, if h'_FE_' = 100 and I'_B_' = 1mA, I'_C_' will be 100 x 1mA or 100mA. This fundamental relationship is the basis of the transistor both when used as a switch and when used as an amplifier. (:nl:)(:table style="clear:both":)
Page last modified on July 29, 2011, at 10:12 AM
