Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors ## Transistor Construction ## Transistor Symbols and Connections ## Transistor Operation ## Current flow Model ## Examples: Current Flow Model ## Transistor as a Current Amplifier ## Worksheet: Transistor as a Current Amplifier ## Transistor as a Switch * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Transistor Operation<^< Transistor Symbols and Connections | Course Index | Current flow Model >^>(:nl:) The equation which relates current flow in the collector, base, and emitter currents is: I'_E_' = I'_B_' + I'_C_' where I'_E_'is the emitter current, I'_B_'is the base current, and I'_C_' is the collector current (all expressed in the same units). In normal operation the base-emitter junction is forward biased and, for a typical silicon transistor, the voltage between the base and the emitter will be approximately 0.65V when the transistor is operating in a conventional amplifier stage. (:nl:)(:table style="clear:both":)
Page last modified on July 29, 2011, at 10:47 AM
