Recent Changes - Search:
<^< Transistors | Course index | Transistor Symbols and Connections >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors ##
Transistor Construction ## Transistor Symbols and Connections ## Transistor Operation ## Current flow Model ## Examples: Current Flow Model ## Transistor as a Current Amplifier ## Worksheet: Transistor as a Current Amplifier ## Transistor as a Switch * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Transistors | Course Index | Transistor Symbols and Connections >^>(:nl:)
Bipolar transistors comprise N-P-N or P-N-P junctions of semiconductor material. The junctions are, in fact, produced in a single slice of silicon by diffusing impurities through a photographically reduced mask. The diagram shows a cross-section through the silicon slice of an NPN transistor.
The name 'transistor' is, in fact, short for transfer resistor. This term provides a clue as to how the device operates; the current flowing in the output circuit is determined by the current flowing in the input circuit.
Transistors fall into two main categories (bipolar and field-effect) and are also classified according to the semiconductor material employed (silicon or germanium) and to their field of application. (:nl:)(:table style="clear:both":)
Page last modified on July 22, 2011, at 09:34 AM
