Ribbon Toolbar
Revision as of 12:39, 26 October 2020 by BenR (talk | contribs) (→‎File Menu)
Introduction
The Flowcode environment consists of a main work area in which the flowchart windows are displayed, several toolbars that allow icon and components to be added to the flowchart application, windows that allow the status of the microcontroller and attached components to be viewed and windows that display variables and macro calls when the flow chart is being simulated.
From the View menu you are able to customise Flowcode to hide and display panel windows such as the Dashboard Panel, System Panel, Properties Panel, Component Debugger and much more, you can also show / hide the Toolbars referenced as Toolboxes, e.g. the 'Main Toolbar', 'Components Toolbar' or rather Toolbox, as well as the 'Icons Toolbar' otherwise known as the 'Command Toolbox'
Video instructions
See the Accessing and Arranging Flowcode Panels video to learn how to organize the application to your preference and manage your work space effectively for optimal productivity and ease of access.
Watch the Toolbars and Buttons video to learn how to use each toolbar effectively as well as learning specific details and functions of each toolbar button.
Finally, view the Tabbed Flowcharts and Macros video to see how to control the interface when managing macros, from tabbed flowcharts and macros to viewing two macro flowcharts on one screen.
FXa7LJsRvAs}} 9c6FIZTfGmA}}
{{#ev:youtube|c0d47BSkKS4}}
File Menu
The file menu allows you to start a new project, open an existing project and save a project.
You can also import a 3D model onto the 3D panel and export the project as a component or App Deleoper application.
Edit Toolbar
The edit toolbar provides some common items to simplify program editing such as copy, paste and icon grouping.
Undo
Redo
Cut
Copy
Paste
Delete
Bookmark
Annotation
Group
Ungroup
Customise C Code
Toggle Disable
Key Mappings
View Toolbar
The following elements can be switched on and off using the view toolbar section of the main ribbon.
Project Explorer
2D: Dashboard Panel
The Dashboard Panel provides a 2D window on which to load Flowcode components. It can be used for any component but is suited towards none 3D components such as buttons, switches, displays.
3D System Panel
The System Panel provides a 3D (real-world) framework on which to load Flowcode components to provide a 3D simulation. It can be used for most components however will not work with the new 2D only GUI simulation components.
Component Properties
The component properties window allows you to view and edit settings specific to the current selected component. The top of the window features a drop down list which lists all of the panel components included in the project.
Find_and_Replace
The find and replace window allows you to search the current macro or project for a keyword and provides means to replace the keyword and filter by icon type.
Change History
A text based history of recent changes in the program allowing you to jump forwards and backward through the change history.
Data Recorder
A means to see waveform history during simulation or using Ghost enabled hardware.
Oscilloscope
A means to see repeating waveforms as you would on a standard oscilloscope during simulation or using Ghost enabled hardware.
Consoles
Used for textual based logs or debugging, various components may create a tab on the console to allow you to easily see data flow or other debugging data.
Component_Debugger
Used to provide addition advanced debugging when creating components, allows you to look inside the component object tree as well as monitor Flowcode execution events and debug messages.
Analog Window
The analogue inputs window monitors the various analogue input pins on the selected target microcontroller device.
Digital Pins
The digital pins window monitors the various digital input / output pins on the selected target microcontroller device.
Watch Window
Wiki
Licensing
Forums
Target Device
The pins of the selected target microcontroller is displayed in this window.
When the flowchart is being simulated, the state of the microcontroller I/O ports are shown on the microcontroller as red and grey for high and low outputs respectively.
Icon Lists
Zoom
Global Settings
A window for various application settings such as icon draw style, component include directories and network settings.
Status Bar
A bar at the bottom of the application showing useful information.
Icons Toolbar
Drag and drop Flowchart and State Diagram icons from the Command Icons toolbar onto the main flowchart window to create your flowchart application.
The Icons tab of the Project explorer window also contains Flowchart and State Diagram icons.
Components Toolbar
This toolbar displays the component libraries that can be included in your program. Click on a component and it can be added onto either the Dashboard Panel or the System Panel and will be automatically connected to the microcontroller in the Chip view.
The properties of the component such as Pin connections, Configuration Parameters and other settings can be edited using the Properties window.
Debug Toolbar
Use this command to display and hide the Toolbar, which includes buttons for some of the most common commands in Flowcode, such as 'Open' (File > Open), 'Print' (File > Print) as well as Compiling the flowchart to Chip, HEX and C. You can even control simulation by running, pausing and stopping simulation using this toolbar as stepping into and over icons to simulate step by step.
11) Status Bar
4) Flowchart Window
System Panel
Compiler Messages
