The PIC 16F88 chip has 13 pins which can be connected to the outside world. Other PICmicros have more or less pins, but the general philosophy is the same. Each of the pins can be either an input (we can use it to sense a voltage which may be applied to it) or an output (we can use it to produce a voltage).
At the moment we are considering purely digital behaviour, in that the signals will be either on or off. Other PIC microcontrollers have components which let them measure voltage levels and convert them to numbers (Analogue to Digital Converters). The PIC microcontroller provides locations in the Special Function Register area which are used to interact with these pins. Such locations are called ports.
The 13 Programmable Input/Output (PIO) pins on the PIC16F88 are provided in two ports. Port A has 5 bits and Port B has eight bits.
The two tables on the right show the arrangement of the ports. Each pin is mapped onto a single bit in a given port. Because of the way that binary numbers are stored we can say that putting a particular power of two into a port will set one of the bits. For example, putting the value 2 into Port B will set the bit RB1 (note that we number pins starting at 0). If that bit was configured as an output it would mean that we are setting pin 7 on the PIC microcontroller into the high state.
We can set several pins high at the same time by adding our powers of two together. For example to set RA3 and RA4 high we would use:
8 (the value for RA3) plus 16 (the value for RA4) - giving a value of 24 for Port A.
This would set pins 3 and 2 high. We will have to get used to combining powers of two in this way, we will also use these tricks to set the data direction registers. Note that we can control the state of the bits in a register by loading an eight bit value (which would update all the pins at once) or by setting or clearing individual pins. We will look at how this is done a little later.
Port A
Bit No.
Bit 7
Bit 6
Bit 5
Bit 4
RA4
Bit 3
RA3
Bit 2
RA2
Bit 1
RA1
Bit 0
RA0
Power of 2
128
64
32
16
8
4
2
1
HEX value
0x80
0x40
0x20
0x10
0x08
0x04
0x02
0x01
N/C
N/C
N/C
PIN 3
PIN 2
PIN 1
PIN 18
PIN 17
Port B
Bit No.
Bit 7
RB7
Bit 6
RB6
Bit 5
RB5
Bit 4
RB4
Bit 3
RB3
Bit 2
RB2
Bit 1
RB1
Bit 0
RB0
Power of 2
128
64
32
16
8
4
2
1
HEX value
0x80
0x40
0x20
0x10
0x08
0x04
0x02
0z01
PIN 13
PIN 12
PIN 11
PIN 10
PIN 9
PIN 8
PIN 7
PIN 6
