Recent Changes - Search:
<^< Capacitance | Course index | Electric Field Strength >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles ## Electrostatics ## Electric Fields ## Capacitance ##
Charge on a Capacitor ## Electric Field Strength ## Examples: Electric Field Strength ## The Unit of Capacitance ## Charge Capacitance and Voltage ## Energy Stored in a Capacitor ## Examples: Capacitance ## The Unit of Inductance ## Flux Linkage and Current ## Energy Stored in an Inductor ## Examples: Inductance ## Magnetism ## Electromagnetism ## Magnetic Fields ## Electromagnets ## Magnetic Field Strength ## Examples: Magnetism * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Capacitance | Course Index | Electric Field Strength >^>(:nl:)
It should now be apparent that an electric field will appear within the capacitor whenever a potential difference is applied to the plates. At the same time, a positive charge will appear on one of the plates and an equal (but opposite) charge will appear on the other.
The value of the charge present, Q, is:
* Directly proportional to the capacitance of the capacitor (the larger the capacitance the larger the charge) * Directly proportional to the voltage between the capacitor plates (the larger the voltage the larger the charge).
In fact, the charge on a capacitor is given by:
Q = C V
Where Q is the charge in Coulomb, C is the capacitance (in Farad) and V is the voltage (in Volts).
>>id=box1 class=toggle center<<
>><< >>id=box2 class=toggle center<<
>><< >>id=box3 class=toggle center<<
V = 12 V, F = 10 &#956;F
V = 100 V, F = 10 &#956;F
V = 100 V, F = 1000&#956;F
(:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 09:20 AM
