Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles ## Electrostatics ## Electric Fields ## Capacitance ## Charge on a Capacitor ## Electric Field Strength ## Examples: Electric Field Strength ## The Unit of Capacitance ## Charge Capacitance and Voltage ## Energy Stored in a Capacitor ## Examples: Capacitance ## The Unit of Inductance ## Flux Linkage and Current ## Energy Stored in an Inductor ## Examples: Inductance ## Magnetism ## Electromagnetism ## Magnetic Fields ## Electromagnets ## Magnetic Field Strength ## Examples: Magnetism * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Examples: Capacitance<^< Energy Stored in a Capacitor | Course Index | The Unit of Inductance >^>(:nl:) >>frame round<< Example 1: A voltage is changing at a uniform rate from 10V to 20V in a time of 1s. If this voltage is applied to a capacitor of 100µF, determine the current that will flow. >><<
>>id=example1 class=question margin=10px frame round<< Now the current flowing will be given by: I = C x (rate of change of voltage), thus: ![]() = = 100 x 10'^-6^' x 10 = 1 x 10'^-3^' = 1mA >><< >>frame round<< Example 2: A potential difference of 150V appears across the terminal of a 2µF capacitor. Determine the amount of charge stored. >><<
>>id=example2 class=question margin=10px frame round<< Q = C V = 2 x 10'^-6^' x 150 = 300µC >><< >>frame round<< Example 3: Determine the energy stored in a 100µF capacitor when a potential difference of 20V is applied to it. >><<
>>id=example3 class=question margin=10px frame round<< Using W = ½ C V'^2^' gives: W = ½ x 100 x 10'^-6^' x (20'^2^') -> = 50 x 10'^-6^' x 400 -> = 20 x 10'^-3^' -> = 20mJ >><<(:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 09:39 AM
