Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles ## Electrostatics ## Electric Fields ## Capacitance ## Charge on a Capacitor ## Electric Field Strength ## Examples: Electric Field Strength ## The Unit of Capacitance ## Charge Capacitance and Voltage ## Energy Stored in a Capacitor ## Examples: Capacitance ## The Unit of Inductance ## Flux Linkage and Current ## Energy Stored in an Inductor ## Examples: Inductance ## Magnetism ## Electromagnetism ## Magnetic Fields ## Electromagnets ## Magnetic Field Strength ## Examples: Magnetism * Electrical Circuits * Alternating Current * Assessment: Fundamentals Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Examples: Inductance<^< Energy Stored in an Inductor | Course Index | Magnetism >^>(:nl:) >>frame round<< Example 1: A current increases at a uniform rate from 1A to 4A in a period of 0.5ms. If this current is applied to an inductor of 1.5H, determine the voltage induced. >><<
>>id=example1 class=question margin=10px frame round<< Now the induced voltage will be given by: e = - L x ( rate of change of current ) >>frame round<< Example 2: A current of 1.5A flows in an inductor of 2H. Determine the flux present if there are 600 turns on the inductor. >><<
>>id=example2 class=question margin=10px frame round<< Re-arranging NΦ = L I to make Φ the subject gives: Φ = L I / N = 2 x 1.5/600 = 5 mWb >><< >>frame round<< Example 3: Determine the energy stored in an inductor of 60mH when a current of 2A is applied to it. >><<
>>id=example3 class=question margin=10px frame round<< Using W = ½ C V2 gives: Using E = 0.5 L I'^2^' gives: E = 0.5 x 60 x 10'^-3^' x (22) = 30 x 10'^-3^' x 4
Page last modified on August 01, 2011, at 09:42 AM
