Recent Changes - Search:
<^< Worksheet: Non-inverting Amplifier | Course index | Worksheet: Differential Amplifier >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits ## Symbols and Signal Connections ## Power Supply Connections ## Dual Supply Configurations ## Voltage Gain ## Worksheet: Voltage Gain ## Input Resistance ## Output Resistance ## Input Offset Voltage ## Inverting Amplifier ## Worksheet: Inverting Amplifier ## Non-inverting Amplifier ## Worksheet: Non-inverting Amplifier ##
Differential Amplifier ## Worksheet: Differential Amplifier ## Direct Coupled Amplifier ## Worksheet: Direct Coupled Amplifier * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Worksheet: Non-inverting Amplifier | Course Index | Worksheet: Differential Amplifier >^>(:nl:)
The basic differential amplifier uses four external resistors: R'_IN_' (=R'_1_'=R'_2_') which defines the input resistance and R'_F_' (=R'_4_'=R'_3_') which defines the closed-loop voltage gain. Thus:
Input resistance = 2 × R'_IN_'
and:
Voltage gain, A'_V_' = R'_F_'/R'_IN_'
Note that neither side of the input signal is taken to the common 0V rail and the signal is said to be balanced. (:nl:)(:table style="clear:both":)
Page last modified on July 29, 2011, at 09:44 AM
