(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:)
(:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :)
* Print
(:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:)
* %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]]
(:ifend:) :)
* Login
<^< Symbols and Signal Connections | Course Index | Dual Supply Configurations >^>(:nl:)
Most (but not all) operational amplifiers require a symmetrical supply of typically between ±5V and ±15V. This allows the output voltage produced by the amplifier to swing both positive (above 0V) and negative (below 0V). Note that, to keep things simple, power supply connections are not always shown on circuit diagrams.
The maximum output voltage swing is usually within about 0.1V or 0.2V of the supply rail voltages.
(:nl:)(:table style="clear:both":)
<^< Symbols and Signal Connections | Course index | Dual Supply Configurations >^>
