Recent Changes - Search:
<^< Non-inverting Amplifier | Course index | Differential Amplifier >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits ## Symbols and Signal Connections ## Power Supply Connections ## Dual Supply Configurations ## Voltage Gain ## Worksheet: Voltage Gain ## Input Resistance ## Output Resistance ## Input Offset Voltage ## Inverting Amplifier ## Worksheet: Inverting Amplifier ## Non-inverting Amplifier ##
Worksheet: Non-inverting Amplifier ## Differential Amplifier ## Worksheet: Differential Amplifier ## Direct Coupled Amplifier ## Worksheet: Direct Coupled Amplifier * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Non-inverting Amplifier | Course Index | Differential Amplifier >^>(:nl:)
Objective: To investigate a non-inverting operational amplifier.
Underpinning knowledge: Operational amplifier symbols and connections.
Apparatus: TINA circuit file, or apparatus to make the following circuit.
TINA Circuit File: Click here to download circuit file
Initial Settings: V'_in_' = 1V, R'_IN_' = R'_F_' = 100k&#937;.
Requires: Paper, Linear graph paper, pen or pencil.
Instructions:
(a) Set V'_in_' = +1V
(b) Set R'_IN_' = R'_F_' = 100k&#937;
(c) Measure and record the values of V'_in_' and V'_out_' (using VM1).
(d) Repeat (c) for each of the following conditions:
* R'_F_' = 300k&#937; * R'_F_' = 500k&#937; * R'_F_' = 700k&#937; * R'_F_' = 900k&#937;
(e) Set V'_in_' = -1V
(f) Repeat steps (b) to (d) above.
Observations:
(a) Comment on the results obtained.
(b) Show that the output voltage, Vout, of the amplifier is given by: Vout = AV x V'_in_' where AV is the voltage gain of the amplifier given by: AV = 1 + R'_F_'/R'_IN_'
Further work:
With R'_F_' set to 900k&#937;, vary the input voltage, V'_in_', from -1V to +1V in appropriate steps and record values of Vout. Use these values to plot a graph showing the relationship between V'_out_' and V'_in_'. What does the slope of this graph indicate? Compare the graph with that obtained from the inverting amplifier assignment
(:nl:)(:table style="clear:both":)
Page last modified on July 28, 2011, at 10:47 AM
