Recent Changes - Search:
<^< Input Resistance | Course index | Input Offset Voltage >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits ## Symbols and Signal Connections ## Power Supply Connections ## Dual Supply Configurations ## Voltage Gain ## Worksheet: Voltage Gain ## Input Resistance ##
Output Resistance ## Input Offset Voltage ## Inverting Amplifier ## Worksheet: Inverting Amplifier ## Non-inverting Amplifier ## Worksheet: Non-inverting Amplifier ## Differential Amplifier ## Worksheet: Differential Amplifier ## Direct Coupled Amplifier ## Worksheet: Direct Coupled Amplifier * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
Output Resistance
<^< Input Resistance | Course Index | Input Offset Voltage >^>(:nl:)
The output resistance of an operational amplifier is defined as the ratio of open-circuit output voltage to short-circuit output current expressed in ohms. Typical values of output resistance range from less than 10&#937; to around 100&#937; depending upon the configuration and amount of feedback employed.
Output resistance is the ratio of open-circuit output voltage to short-circuit output current, hence:
R'_OUT_' = V'_OUT_'(OC)/I'_OUT_'(SC)
where R'_OUT_' is the output resistance (in &#937;), V'_OUT_'(OC) is the open-circuit output voltage (in V) and I'_OUT_'(SC) is the short-circuit output current (in A). (:nl:)(:table style="clear:both":)
Page last modified on July 25, 2011, at 02:07 PM
