Recent Changes - Search:
<^< Differential Amplifier | Course index | Direct Coupled Amplifier >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits ## Symbols and Signal Connections ## Power Supply Connections ## Dual Supply Configurations ## Voltage Gain ## Worksheet: Voltage Gain ## Input Resistance ## Output Resistance ## Input Offset Voltage ## Inverting Amplifier ## Worksheet: Inverting Amplifier ## Non-inverting Amplifier ## Worksheet: Non-inverting Amplifier ## Differential Amplifier ##
Worksheet: Differential Amplifier ## Direct Coupled Amplifier ## Worksheet: Direct Coupled Amplifier * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
Worksheets: Differential Amplifier
<^< Differential Amplifier | Course Index | Direct Coupled Amplifier >^>(:nl:)
Objective: To investigate a differential operational amplifier.
Underpinning knowledge: Operational amplifier symbols and connections.
Apparatus: TINA circuit file, or apparatus to make the following circuit.
TINA Circuit File: Click here to download circuit file
Initial Settings: V'_in1_' = V'_in2_' = 0V, R'_1_' = R'_2_' = 100k&#937;, R'_3_' = R'_4_' = 500k&#937;
Requires: Paper, Linear graph paper, pen or pencil.
Instructions:
(a) Set R'_1_' = R'_2_' = 100k&#937; and R'_3_' = R'_4_' = 500k&#937;
(b) Set V'_in1_' and V'_in2_' to 0V
(c) Measure and record the values of V'_in1_', V'_in2_' and V'_out_' (using VM1).
(d) Repeat (c) for each of the following conditions:
* V'_in1_' = +1V and V'_in2_' = 0V * V'_in1_' = 0V and V'_in2_' = +1V * V'_in1_' = -1V and V'_in2_' = 0V * V'_in1_' = 0V and V'_in2_' = -1V * V'_in1_' = +1V and V'_in2_' = +1V * V'_in1_' = -1V and V'_in2_' = -1V
(e) Set R'_1_' = R'_2_' = 100k&#937; and R'_3_' = R'_4_' = 1M&#937;
(f) Repeat (b) to (d) above.
Observations:
(a) Comment on the results obtained.
(b) Show that the output voltage, V'_out_', of the amplifier is given by: V'_out_' = -R'_F_'/R'_in_' x (V'_in1_' - V'_in2_') where R'_F_' = R'_3_' = R'_4_' and R'_in_' = R'_1_' = R'_2_'
Further work:
With R'_3_' = R'_4_' = 1M&#937; and R'_1_' = R'_2_' = 100k&#937;, use the data obtained earlier to plot a graph showing the relationship between V'_out_' and (V'_in1_' - V'_in2_'). What does the slope of this graph indicate?
(:nl:)(:table style="clear:both":)
Page last modified on July 28, 2011, at 09:55 AM
