Recent Changes - Search:
<^< Input Offset Voltage | Course index | Worksheet: Inverting Amplifier >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits ## Symbols and Signal Connections ## Power Supply Connections ## Dual Supply Configurations ## Voltage Gain ## Worksheet: Voltage Gain ## Input Resistance ## Output Resistance ## Input Offset Voltage ##
Inverting Amplifier ## Worksheet: Inverting Amplifier ## Non-inverting Amplifier ## Worksheet: Non-inverting Amplifier ## Differential Amplifier ## Worksheet: Differential Amplifier ## Direct Coupled Amplifier ## Worksheet: Direct Coupled Amplifier * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
Inverting Amplifier
<^< Input Offset Voltage | Course Index | Worksheet: Inverting Amplifier >^>(:nl:)
A basic inverting operational amplifier uses just three external resistors: R'_IN_' which defines the input resistance, R'_F_' which defines the closed-loop voltage gain, and a third resistor described below. Thus:
Input resistance = R'_IN_'
and it can be shown that:
Voltage gain, A'_V_' = R'_F_'/R'_IN_'
Since the input signal is taken to the inverting '-' input of the operational amplifier, the output is said to be 180° out of phase with the input. In other words, the amplifier inverts the signal.
The third resistor, R'_1_', is inserted in the non-inverting input in order to improve symmetry. Its value is chosen so that it is equal to the parallel combination of the input resistance, R'_IN_', and the feedback resistance R'_F_'. In practice, R'_F_' is usually very much larger than R'_IN_' and thus the resistance value is often made the same as that used for R'_IN_'.
Note that the value of the resistor has no effect on the gain of the stage it is simply there to ensure that both inputs "see" the same external resistance. (:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 01:23 PM
