Recent Changes - Search:
<^< Direct Coupled Amplifier | Course index | Transistor Amplifier Circuits >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits ## Symbols and Signal Connections ## Power Supply Connections ## Dual Supply Configurations ## Voltage Gain ## Worksheet: Voltage Gain ## Input Resistance ## Output Resistance ## Input Offset Voltage ## Inverting Amplifier ## Worksheet: Inverting Amplifier ## Non-inverting Amplifier ## Worksheet: Non-inverting Amplifier ## Differential Amplifier ## Worksheet: Differential Amplifier ## Direct Coupled Amplifier ##
Worksheet: Direct Coupled Amplifier * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Direct Coupled Amplifier | Course Index | Transistor Amplifier Circuits >^>(:nl:)
Objective: To investigate a direct coupled amplifier
Underpinning knowledge: Operational amplifier symbols and connections
Apparatus: TINA circuit file, or apparatus to make the following circuit.
TINA Circuit File: Click here to download circuit file
Initial Settings: V'_in_' = 1V at 1kHz, R'_IN_' = 100k&#937;, R'_F_' = 500k&#937;.
Requires: Paper, Linear graph paper, pen or pencil.
Instructions:
(a) Set V'_in_' = 1V at 1 kHz
(b) Set R'_IN_' = 100k&#937;, R'_F_' = 500k&#937;
(c) Select 'AC conditions'
(d) Observe the output waveform produced by the amplifier. Sketch two complete cycles of the output waveform and include labelled axes of voltage (V'_out_') and time (t).
(e) Repeat (d) for R'_F_' = 1M&#937; and R'_F_' = 2M&#937;.
Observations:
(a) Comment on the waveforms produced. Do these indicate a phase inversion?
(b) Show that the voltage gain, AV, of the amplifier is given by: AV = -R'_F_'/R'_IN_'
(c) Explain what happened when R'_F_' = 2M&#937;. What caused the distortion in the output waveform?
Further work:
Design an inverting amplifier with a voltage gain of 40 and an input resistance of 20k&#937;. Sketch the circuit diagram for the amplifier showing the component values. Test the amplifier using TINA and verify that a voltage gain of 40 is achieved.
(:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 01:27 PM
