Recent Changes - Search:
<^< Operational Amplifier Circuits | Course index | Power Supply Connections >^>
Electronic circuits and components * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * How to use this Course * TINA * Locktronics
Fundamentals * Introduction: Fundamentals * Units and Multiples * Electricity * Electronic Principles * Electrical Circuits * Alternating Current * Assessment: Fundamentals
Passive Components * Introduction: Passive Components * Resistors * Capacitors * Inductors * Transformers * Batteries, Fuses, Lamps and Switches * Assessment: Passive Components
Semiconductors * Introduction: Semiconductors * Diodes * Transistors * Logic Gates * Assessment: Semiconductors
Passive Circuits * Introduction: Passive Circuits * Series and Parallel Connections * Kirchoff's Laws * Potential and Current Dividers * Passive Time Variant Circuits * Assessment: Passive Circuits
Active Circuits * Introduction: Active Circuits * Power Supply Circuits * Operational Amplifier Circuits ##
Symbols and Signal Connections ## Power Supply Connections ## Dual Supply Configurations ## Voltage Gain ## Worksheet: Voltage Gain ## Input Resistance ## Output Resistance ## Input Offset Voltage ## Inverting Amplifier ## Worksheet: Inverting Amplifier ## Non-inverting Amplifier ## Worksheet: Non-inverting Amplifier ## Differential Amplifier ## Worksheet: Differential Amplifier ## Direct Coupled Amplifier ## Worksheet: Direct Coupled Amplifier * Transistor Amplifier Circuits * 555 Timer Circuits * Assessment: Active Circuits
Parts Gallery * Introduction: Parts Gallery * Passive Component Images * Semiconductor Images * Other Images * Quizzes
<^< Operational Amplifier Circuits | Course Index | Power Supply Connections >^>(:nl:)
Operational amplifiers have two signal input connections and one signal output connection. One of the signal inputs is marked '-' and the other is marked '+'. These polarity markings have nothing to do with the supply connections - they indicate the overall phase shift between each input and the output. The '+' sign indicates zero phase shift and the '-' sign indicates 180° phase shift. Since 180° phase shift produces an inverted (i.e. turned upside down) waveform, the '-' input is often referred to as the 'inverting input'. (:nl:)(:table style="clear:both":)
Page last modified on August 01, 2011, at 01:16 PM
